OMG I NEED HELP :|
OMG I NEED HELP :|
Postby slighty_looney » Tue Mar 07, 2006 10:22 pm
Hey all, im from palmy and im up in aucks for block cource, when i went to put my ciggerte lighter in my headunit turned off, my lighter wudnt work, my heating fan wudnt work, aircon wudnt work, so i drove round wid a map trying 2 find home with buga all vison (cause she was alllll fogged up), i dnt wana drive back 2 palmy wid that and no stero or radar ! please please help, oh my cars a 1994 toyota trueno gt-apex manual
thanks heaps
Looney
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby rage » Tue Mar 07, 2006 10:25 pm
check your fuses.
rage
Postby badidas » Tue Mar 07, 2006 10:28 pm
probably a short somewhere most likly the headunit wiring
1989 mazda bongo aka [BNGBUS]
badidas
Postby slighty_looney » Tue Mar 07, 2006 10:37 pm
checks all the little fuses, 10amp 15amp 20amp ect they r all fine, its not the wiring on the headunit, its been in for a year now and redfox installed it, any1 plz help, im not stupid and i checkd the ovious things, i jst thought sum1 else mita had that problem in there 20v
FC3S
slighty_looney
Postby Alex B » Tue Mar 07, 2006 10:39 pm
Checked the dome fuse under the bonet?
Postby slighty_looney » Tue Mar 07, 2006 10:46 pm
dome fuse? iv got like 1 big fuse box on the right side under my bonnit, i chekd the fuses i know bout, ( 15amp ect ) but theres other bigs ones in there i wudnt hava clue wat they r :S
FC3S
slighty_looney
Postby fangsport » Tue Mar 07, 2006 10:51 pm
if all those have suddenly stopped working, you have blown a fuse. the ciggy lighter has shorted the circuit out, quite common.
fangsport
Postby Caveman » Tue Mar 07, 2006 10:52 pm
There is a fuse box which should be on the driver kick panel :) check those fuses, when you replace it its best to find what caused the blow fuse, i cant talk though i never do that :lol:
Caveman
Postby slighty_looney » Wed Mar 08, 2006 7:13 am
kick panel?
FC3S
slighty_looney
Postby MrOizo » Wed Mar 08, 2006 8:03 am
slighty_looney wrote: im not stupid and i checkd the ovious things
slighty_looney wrote:kick panel?
8O :o
Kick panel is down by your feet. most likely to the right in the drivers seat.
That does sound like the Dome fuse too.
MrOizo
Toyspeed Legend
Postby Ae92typeX » Wed Mar 08, 2006 8:19 am
Thats where the majorty of your fuses are really. Onle afew under the hood fuse/relay box.
Ae92typeX
Postby gordon77 » Wed Mar 08, 2006 9:40 am
yup had the exact same thing happen to me when i wired my headunit backwards 8) there should be a diagram on the back of the little panel u pull off to access the fuses that will tell you which one to pull out.
What is RR?
gordon77
Postby slighty_looney » Wed Mar 08, 2006 4:17 pm
there in no kick panel is 20v truenos ! im sure theres not theres 2 fuse boxes under the hood, i checkd them both and all the fuses seem to b fine, im completly lost ! :(
FC3S
slighty_looney
Postby sergei » Wed Mar 08, 2006 4:26 pm
There is a fuse box thing just next to gas pedal, you will find the fuse which is responsible for clock/lighter is named "CIG/RADIO" on the cover from the panel which covers the fuse box.
Postby slighty_looney » Wed Mar 08, 2006 5:51 pm
thanks man, found it :D sum1 puta 10amp fuse in there and its suppost to b 20amp, all gud now thanks again man
FC3S
slighty_looney
Postby fangsport » Wed Mar 08, 2006 5:56 pm
slighty_looney wrote:thanks man, found it :D sum1 puta 10amp fuse in there and its suppost to b 20amp, all gud now thanks again man
check the state of your ciggy lighter, the element breaks down after lots of use and shorts the wiring out
fangsport
Postby Psycho_Dad » Wed Mar 08, 2006 6:38 pm
also, make sure your fuel cap is secured properly, and perhaps buy a haynes manual just to see how to do that.... its very important and it could just save your life
im kidding, congrats on finding a new part of your car(which is commonly known as "the drivers side kick panel fusebox"-or tdskpf for short) go with this wisdom and breed your new found knoledge
Peace
PSycho_Dad
Psycho_Dad
