jasestu wrote:"Published comments are a representative selection of the feedback we are sent, not all feedback is published."
- http://www.noiseoff.co.nz/news/comments.htm
Representitive? There's not a single comment mentioning the other side of the arguement.
jasestu wrote:The key thing for me is 'loud' vs 'releasing the melody of the engine'. Loud/droning exhausts annoy me to, but it's all about balance. Thing is tho, loud to one person might not be to another. For some people any car sound is very intrusive. Like you say, guess that's why they regulate relative to the sound from factory.
barryogen wrote:jasestu wrote:"Published comments are a representative selection of the feedback we are sent, not all feedback is published."
maybe no-one has sent them anything from the noisey car exhaust supporters group?
Punter wrote:barryogen wrote:jasestu wrote:"Published comments are a representative selection of the feedback we are sent, not all feedback is published."
I've adjusted your highlighting
barryogen wrote:90dB is loud, loud enough that no road legal car should have to be that loud, at 8300RPM, mine was measured at 87dB(using the proposed testing method), and that was once the cat and siliencer were removed(for track use)
purple_beasty wrote:barryogen wrote:90dB is loud, loud enough that no road legal car should have to be that loud, at 8300RPM, mine was measured at 87dB(using the proposed testing method), and that was once the cat and siliencer were removed(for track use)
What distance was that at? In the testing I have seen they recommended 95dB at 0.5m and 45 degrees as the limit at 3500 to 4000rpm.
TRD Man wrote:No, the TRD muffler is not considered factory standard equipment for this purpose.
Punter wrote:Can you buy a new corolla from toyota with a TRD exhaust? NO
Can you buy a new falcon from FPV with and FPV exhaust? YES
Timmo wrote:ie "Your exhaust is too loud as it exceeds xxxx decibels" as opposed to " Your exhaust is too loud because i think so"
I think that many car enthusiasts would actually prefer a set DB limit- at least you know what is legal and what isnt....
Timmo wrote: Technically, if you import that car to NZ its 'as the factory intended'.....
BlakJak wrote:BTW to use the Harley Example is shady, coz most 'overly loud' harleys have had their mufflers removed.
(They get refitted at wof type, typically)
Aka their owners are pricks...
