ae85 needed a 3sgte
ae85 needed a 3sgte
Postby blue-smoke » Fri Mar 10, 2006 7:22 pm
i have recently been given a ae85 (lower model to the 86 4age) and im thinking about putting in a 3sgte and im wondering how much of a mission would it be? i will use the t50 if i can and upgrade to a lsd
blue-smoke
Postby evil_si » Fri Mar 10, 2006 7:27 pm
i wouldnt bother with the t50.
i dont even think a bellhousing is available,
use a w55 up series box
evil_si
Postby Adydas » Fri Mar 10, 2006 7:29 pm
Adydas
Postby Malcolm » Fri Mar 10, 2006 9:24 pm
dont bother with the 3s, it's cheaper and easier to go 1UZ
Postby strx7 » Fri Mar 10, 2006 9:31 pm
be different and drop a 1JZ or 2JZ into it
I'll fit, you just need to mount the radiator on the front side of the rad support panel, I did the measurements, its either that or chop some firewall.
A Cammy 1JZGE with 6 50mm TB's and equal length extractors would look right at home under the bonnet........
Postby KinLoud » Fri Mar 10, 2006 9:44 pm
Hi.
It certainly is possible to do this. I would rate it as a medium difficulty mission (on the VVEGA scale of mechanical and fabrication difficulty :)). Quite a few people have done this before.
Gearbox
- Your AE85 has a K50 gearbox, the torque from a 3sgte will turn the insides into metal filings within 3 hours (or even less)
- AE86's have a T50 gearbox, there are bellhousings for the T50 that will suit the S series motors (I have a spare bellhousing). However the T50 gearbox will turn into metal filings in about 3 days.
- find any W55/W57/W58 gearbox. Find a C, S or Y bellhousing for the gearbox. It won't break for 3 years (at least!!!) Bellhousing... $75ish gearbox... from free up to $350 for W55, W57 $350 up to $550, W58 $450 up...
Motor
- Try to find a 3sgte in a damaged car. That way you will have everything you need to make the engine go. Computer, loom, engine, turbo, bolts, brackets.... about a million little things that are a real bugger to find because you don't know what they look like if you don't have them!!!
LSD
- The AE86 rear axle with disk brakes will bolt into your AE85 (except maybe for the swaybar). There are LSDs available that will bolt into the AE86 diff... probably looking at $500 to $800 for the axle if you can find one and $1000 for the LSD. With a 3sgte and some hard driving you will turn the axle into metal filings!
I would recommend talking to the drifter dudes (try Garage Dori website) and follow their advice as to setting up a unbreakable hilux lsd axle in your AE85. Cost.... less than $1000 I'm sure, maybe cheaper!
Homework - look up Phil Bradshaw's website where he was putting a 3sgte into a AE86. Search here on Toyspeed for C, S and Y bellhousings (I have made several posts about this). Yeah do lots of searches here on toyspeed as well as the web in general.
Go do it!
Ken
Ham
021 408 863
Postby blue-smoke » Wed Mar 15, 2006 6:59 pm
thanks bro
blue-smoke
Postby suberimakuri » Tue Mar 21, 2006 5:18 pm
suberimakuri
