How much stronger is the T50 TRD gearset ?
Postby beeker » Thu Mar 09, 2006 3:56 pm
Just blown my T50 (lucky i have a spare), I believe the input shaft/gear failed.
I want to ensure it wont happen again in a hurry. Is the TRD gearset much stronger than std ?
I guess i can always go W series, but will then have to change the ratios that'll cost about the same??
Any feedback here.
PS. running a Stock boost 4AGZE in the AE86.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby TRD Man » Thu Mar 09, 2006 5:07 pm
The effect of any extra strengthening in the TRD gearkit is not quantifiable.
We've sold them to competitors with reputed 230hp high torque rally engines and they've survived well - although I usually question the accuracy of the claimed power figures.
With your std spec 4AGZE I'd have no doubt the kit would hold up.
But your usage is seal which is harder on the drivetrain than gravel and you need to consider any future mods you're likely to make to the engine.
TRD Man
Postby nzae86 » Sat Mar 11, 2006 7:20 pm
These gearsets are no stronger than standard as the physical width of each gear is the same, they are just different ratios. I have run one in my tarmac car for a couple of years now with no problems so far.
You do need to look at your diff ratio with one of these boxes as getting off the line can be a mission, esp up hill tarmac starts.
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby TRD Man » Sat Mar 11, 2006 10:47 pm
Width has little to do with strength. It's the material content & hardening processes that matter here.
Sometimes size really doesn't matter!
TRD Man
Postby Drifter4ag » Sun Mar 12, 2006 10:59 pm
WBOX
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
