More power from a 1ggte?
Postby MrDori » Mon Mar 13, 2006 10:06 am
atm its running 9psi, ges alright. how much more boost could i run on std ecu std fueling etc?
Coould i go to a bug single with std ecu?
MrDori
Postby Silent Knight » Mon Mar 13, 2006 10:13 am
What is the 1G in at the moment?
Easy and first ones are normally get a good, decent exhaust system. Get your Intake sorted out. Slap on an Intercooler that's not overly big. Just big enough to do what you need it to do.
Then get an EBC and you can wind the boost up a bit. I'm not sure on what boost cut is with the 1G, I have forgotten after the Supra. :?
If you get problems with boost cut just get an FCD and you're away. Watch out for the turbos though as they are not bulletproof. Wind it out too much and they'll pop like corn in a hot pan.
You could go with a bigger single turbo on the motor but there's allot that needs changing for that sort of thing. And yes you could run it from your stock ECU....but what's the point? If you are spending all of the money to convert to single turbo then why not fork out a lil extra and get the whole thing tuned properly with an aftermarket ECU?
That way you'll get the best power out of it.
Silent Knight
Postby Ae92typeX » Mon Mar 13, 2006 8:02 pm
as above, but dont wind the boost too much, they are not the most reliable turbos, and also at high boost they will be just pushing hot air without much gains
Ae92typeX
Postby MrDori » Tue Mar 14, 2006 8:55 am
kinda doing the whole thing on a buget, gana make a collector pipe that joins both manifolds together atm, chuck a t3/t4, can do this for around 800.
ive got a decent front mount on it, no exaust atm 8O
goes alot beta in the lighter chassis
MrDori
Postby Silent Knight » Tue Mar 14, 2006 9:10 am
Budget is always a bad word when it comes to modifying cars.
Let me get this right...you are going to join the stock manifolds together so that you can slap a single on it? - IMHO that would be pointless as the stock manifolds are very restrictive. It would be better to just get a new manifold from the start made with T3/T4 flanges and go single from there.
I don't exactly see how you are going to join the stock manifolds together for a single turbo? - Sounds like allot of hassle for minimal gain to me.
Also you need to be doing your exhaust, at the moment it will be holding you back. If you already have the Intercooler sorted out and you are going single turbo then you'll have to do a new exhaust as it's going to be extremely restrictive and holding everything else back from achieving their full potential.
Silent Knight
Postby UTERUS » Tue Mar 14, 2006 10:20 am
It actually has 'no exhaust' at the moment, just the downpipe :lol:
UTERUS
Postby MrDori » Tue Mar 14, 2006 3:00 pm
Pretty easy really, you have two side by side flanges make a Y pipe to collect them into onewith your t3 style flange, very simple and apperntly quite affective, seen it done in aussie. may get the die grinder out also.
making a whole new manifold sounds rather costly since the whole car has cost my 2500 so far..
can you get fuel cut defencers for afm cars?
MrDori
Postby Drifter4ag » Tue Mar 14, 2006 3:34 pm
Maybe you should dyno it first
then get yourself a sidepipe
stock turbos
intercooler is fine
see how much power you make
some make over 150kw on 14psi which is great
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby MrDori » Wed Mar 15, 2006 12:55 pm
150 is bloody resonable power, id be chuffed with that, it certainly feels as though it has that sorta power.
ohwell power is not everything- maybe i should start trying to tighten this chassis up abit..
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Users browsing this forum: No registered users and 26 guests
