What will this bellhousing bolt to??
Postby UTERUS » Thu Mar 16, 2006 7:42 pm
When i bought it i was told it will bolt onto my G series Hilux gearbox and a G series motor will slide on the other end.
Ok, so what other gearboxes with this bellhousing bolt to? W series?
Also, how much is it worth??
Cheers,
Simon
UTERUS
Postby KE20 » Thu Mar 16, 2006 7:49 pm
will bolt to rwd hilux gearbox, pre'89(square shape) surf 4wd box,'W' box,
its a bit of a common bell, it will also for 3t,1c and a few others as well
can buy from pick a part for $15
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby RedMist » Thu Mar 16, 2006 7:56 pm
G series engine? No such thing. G is the reference to included valve angle on all Toyota engines. Either G or F in the engine code.
I cant say about the box end. Lower two mounts look to high for a 4a bell housing.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby wde_bdy » Thu Mar 16, 2006 7:59 pm
RedMist wrote:G series engine? No such thing. G is the reference to included valve angle on all Toyota engines. Either G or F in the engine code.
You having a blonde moment?
1G-FE
1G-GE
1G-GTE
1G-GZE
:wink:
wde_bdy
Postby UTERUS » Thu Mar 16, 2006 8:00 pm
And the mighty 1G-EU :lol:
UTERUS
Postby Malcolm » Thu Mar 16, 2006 8:12 pm
1G-FE
1G-GE
1G-GTE
1G-GZE
:wink:
nah I think he was making a comment about the G series being so crap you can't really call them motors
:x
Postby Dell'Orto » Thu Mar 16, 2006 8:45 pm
I'd hardly call a 1GZFE a crap engine ;)
Postby UTERUS » Thu Mar 16, 2006 8:49 pm
Mmm, Boost wrote:I'd hardly call a 1GZFE a crap engine ;)
You mean a 1GGZE?
UTERUS
Postby Dell'Orto » Thu Mar 16, 2006 8:51 pm
Nup, 1GZFE. Usually found in these things
I think its Toyotas largest displacement motor in passenger vehicles?
Postby UTERUS » Thu Mar 16, 2006 9:21 pm
Mmmm, 5 litre V12 8O
UTERUS
Postby Malcolm » Thu Mar 16, 2006 9:29 pm
haha that's hardly a G series though is it? Otherwise a 1SZ would be same family as 3S, 2AZ same as 4A, a VZ same as a V and an MZ the same as a M etc! :P
Anyway I was only kidding, I'm sure the G series aren't that bad :)
Postby KE20 » Fri Mar 17, 2006 8:45 pm
well ill give ya $20 for it. then i can manual my gx90, saves me the hassle of going to pick a part and getting one :D
Garage Dori
KE20
