gearbox removal help ***PICS***
Postby bluemaumau » Sun Mar 19, 2006 12:11 pm
ok im doin my first engine removal and ive got all the bolts i think out that join the engine to the clutch flywheel housing,
one bolt remains, im not to sure if this needs removing as it seems near impossible, the only tool that could get it would be a tiny 17mm o ring spanner :cry: - which i dont have.
the box is a e52 coupled to a 4agze afm engine.
this nut is located my the rear gbox mount (next to the firewall)
and is inbetween the clutch/flywheel housing and gearbox housing ,
- the same area the speedo is put in.
i wanna know if this needs to be removed im sure it does, but man what a stupid place to put it! :x
also can any1 tell me how many bolts in total that connect the gbox and engine?
i know its hard to help me but if anyone which the same engine /gbox combo could have a look it would be real helpful.
cheers will
Postby Ae92typeX » Sun Mar 19, 2006 2:57 pm
Got any pictures?- thay would make it easirer...but, going by your description, the 17mm towards the engine, by the speedo drive- than yes, you have to undo it. Have you got the driveshafts off?, should be able to get there with a socket and small extension.
Ae92typeX
Postby bluemaumau » Sun Mar 19, 2006 3:37 pm
yea shafts are off.
the speedo drive is slighty above this nut.
and both this nut and the speedo drive are inbetween the clutch flywheel housing and gearbox.
so you can get a socket on but a ratchet wont fit.
and most o rings are too long and theres no room to turn it! :evil:
dont have camera, will try get one on monday night.
thanks
Postby rallymazda » Sun Mar 19, 2006 6:11 pm
are you trying to undo it from the top or bottom? because I undid mine from the bottom, used an air rachet to take it off though so was a bit easier :)
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby bluemaumau » Sun Mar 19, 2006 8:48 pm
yea im gonna take the x member off completely
atm its hangin off the exhaust ( the x-member)
how did you get a air ratchet in there? unless its a bent gun? :?
Postby Ae92typeX » Sun Mar 19, 2006 10:20 pm
just assuming, but he said air ratchet, not gun anyway, so it would be bent.
Ae92typeX
Postby ee904age » Mon Mar 20, 2006 8:04 am
Im not to sure about the GZE but on my 4AGE I use a socket and a reeeeally long extension. BTW, a 17mm spanner is one of the more common tools on a Toyota so I'd suggest getting one.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby bluemaumau » Mon Mar 20, 2006 10:24 am
i have a 17mm spanner its just its too long so you cant actually get the nut to budge becase its hits either the firewall or gbox housing. -thats why i think i need a tiny 1.
i cant use a long extention because its is inbetween two extruding housings.
Postby Ae92typeX » Mon Mar 20, 2006 7:27 pm
managed to get a picture?, just to make sure everyone is talking about the same piece
Ae92typeX
Postby bluemaumau » Mon Mar 20, 2006 9:00 pm
nah not yet,
i talked to some ppl and they said you can buy right angle spanners, sounds like a winner, ill go inspect tomorrow. :D
Postby sergei » Mon Mar 20, 2006 10:31 pm
I never ever had the problem you described (removed/installed lots of different gearboxes, E5X, C5X, C160, S5X etc)... Are you sure you are removing the right bolt?
if you are talking about long bolt wich goes through rear gearbox mount, it is possible to access it from different angles, say from right side with lots of extensions, or from the bottom, medium extension/u-joint or from top without extension just the ratchet with normal socket on it.
Postby bluemaumau » Tue Mar 21, 2006 6:09 pm
hope this works, if it does i have more :D [/img]
Postby bluemaumau » Tue Mar 21, 2006 6:12 pm
yeah! 8)
hope this helps you guys help me! :D
Postby bluemaumau » Tue Mar 21, 2006 6:47 pm
bump, help! :?
Postby 20v_rollaboy » Tue Mar 21, 2006 7:37 pm
Are you sure its holding on by that bolt? Because it looks like you dont have to remove that one. You only have to remove the three bolts that are holding the mount on and it should come out, unless its holding on somewhere else :wink:
20v_rollaboy
Postby bluemaumau » Tue Mar 21, 2006 8:55 pm
yea i know i must be goin blind, i bet if sum1 else looked theyd see it straight away!!!!
ill double check tomorrow, but that bolt goes thru 2 pieces, so i assumed itll need to be removed :?
Postby bluemaumau » Tue Mar 21, 2006 8:56 pm
btw how hard do you have to pull to get the gbox to slide off? is there anything that could stop this?, eg, leaving it in gear :?
Postby Ae92typeX » Tue Mar 21, 2006 10:00 pm
If it has not been off for a while, it will probably be a little stuck and you will need to 'crack' it off. Buy that, I simply mean you may need to wiggle it side to side a little or perhaps leaver it off for the first cm or so. Being in gear or not makes no difference.
It may be heavy'ish (depending on ones strength), so make sure you are ready when you do it.
Just make sure all driveshafts are out of the way etc and you have the car jacked up enough (with stands!) and its out.
Ae92typeX
Postby bluemaumau » Tue Mar 21, 2006 11:18 pm
ok sweet cheers everyone 8)
Postby l1ttle_d3vil » Wed Mar 22, 2006 10:30 am
yea they can sometimes be pretty hard to pull out; try leavering it off a little bit. if it starts moving a bit you'll know that all the required bolts are off.
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
