crnkin wrote:why supercharge anything
Karl_Skewes wrote:not sc but turbo na redtop exp..
I ran 1 bar t3/4 turbo pushing over 150kw at wheels on my redtop 4age. Ran for ages, did couple d1nz rounds.... megasquirt ecu....
Then the motor was pulled and put as is (minus turbo) into Keith's 86 and he's done 1.5 years on it now, including all the d1nz and other drift days.
can't run much advance... even 20 deg at full boost in parts is too much.
need bp ultimate.
BLAH BLAH BLAH COMPRESSION TO HIGH>>>> BLAH BLAH BLAH.
Stealer Of Souls wrote:I was about to say that Tim had done it...
What boost did you run? What changes did you have to make to get it to run good?
Mr Revhead wrote:yes it is
my aw11 has redtop big port from an ae92 with the aw11 4agze manifolds and ecu etc.
biggest problem is there being no knock sensor hole in the block
need bp ultimate.
