nzae86 wrote:Yes you can get one in fact I have just bought one as part of a dry sump setup , they are made by TRD and I consider mine a bargan at $2500, as a second hand system.
Really if you want that ali look then go and buy yourself some silver paint and save yourself a whole lot of torture of getting one made.If you are worried about bits floating around in your oil the replace your filter with a decent one often
I was on that thread.RomanV wrote:magnetic sump plug thread
Also, why would you want an aluminium sump?
Surely the weight savings would be negligable, and what other reason would there be?
ATAl wrote:But if you ever hit the aluminium sump into the road over a judder bar or something wouldn't it crack? (I'm thinking cast aluminium, maybe your thinking of using something else?)
Just asking this because I've never seen a sump yet which hasn't been hit on the road at some stage in its life.
Yeah. True. But I am getting and engine re-conditioned at the moment. Should be lots of particles to pick up during the run in...Ae92typeX wrote:the other question is, how much magnetic metal particles are you expecting to get in your 4age?
The link above discusses that pretty well
Would it matter then if the sump was alloy or steel or whatever?CAMB01 wrote:At my work we have had two EVO's in for rebuilds cos they are too low and have had their sumps crushed by driving over something. The pickup was blocked from the sump being crushed and it ran bigend bearings
