escortman wrote: ae92 levin 1987 redtop with tvis not sure if its small port or big
boogergrom wrote:or it could be that the tvis bluetop is superior to the tvis redtop:P
escortman wrote:boogergrom wrote:or it could be that the tvis bluetop is superior to the tvis redtop:P
is that true or ur jus been a ass
RedMist wrote:Gentlemen, need I remind you that you are talking about 20 year old engines. Stating that one redtop is superior to a bluetop and then using it as a generic rule is bordering on stupidity.
One may out perform the other in this circumstance. Or may not depending on how accurate your butt dyno is. Your bluetop may just have more induction roar which makes you think its quicker. Or perhaps the redtop is down on compression.
Who knows, and without more information anyone posting a reply is simply speculating without any scientific proof.
The cam duration is slightly longer in the bluetop. Which should produce slightly more up end HP, and possibly slightly less mid range. However its not nearly half enough to get over the parasitic losses in your auto tranny.
