I have tried a circut tester at the spotlight plugs with park/hi/low beam on with no result. I have also tried the circuit tester at the fuse box on the fuse named 'fog' it showed a positive result when the parklights were on.
do the cars fitted with factory lights have a switch of some sort? or do the lights automaticly come on with the park lights?
does this ciruit need a switch or is there a way to hard wire to the park lights using the the existing spotlight wiring i have?
any advice/input appreciated
