CAMB01 wrote:With engine running put a volt meter on the battery and see what voltage you have.
If everything is good it should have 14.4 volts.
Cam
trueno_20v wrote: i got it going and took the ( + ) lead off the battery and it still idled, and then i done the same thing to my dads car
Then your lucky you did not fry the electrics in both of them.
Removing the battery while the car is running is a big no no on cars with electronic's.
Ok on your old farm tractor,
CAMB01 wrote:You must have something on over night thats draining the battery
nobody wrote:Just a thought - make sure your earth connection (that runs from the negative battery terminal to the chassis or frame) is properly connected.
My car had all the symptoms of a flat battery in the mornings, and it turned out to be a faulty earth connection. A bit of a clean up with a wire brush and a good tighten with a socket fixed it right up
CAMB01 wrote:What size cables are you using for the battery if its in the boot?
Where is your earth from the battery going to?
CAMB01 wrote:An earth cable wont earth if it is touching a painted surface.
