Amp Question
Postby toyonut » Wed Mar 22, 2006 2:26 pm
toyonut
Postby Blackrazor » Tue Mar 28, 2006 11:00 am
LOL! Noone picked up the 'this is going in an MR2' bit.
Good luck fitting 1x T2 sub in there, let alone more than one.
You have three options for sub placement in an MR2 :
1) Behind the seats. This requires a shallow sub that works well in a small sealed box, probably a 10" in most cases : Rainbow Hammer, Resonant Engineering RE, DLS Magnesium, Focal Access, etc.
2) Under the hood. This works well but requires MASSIVE amounts of custom work and fibreglassing to do properly, plus you need a high output sub to get the bass at a reasonable volume in the cabin - it has to go through a steel wall afterall.
3) In the boot. Waste of time, dont bother.
If you want to put subs in an MR2 without a lot of work, its behind the seats time. Now unless you're 4'6", that means you've got around 15-25L per sub to play with. So you want small, high output subs with good linear throw that operate in a small box - Rainbow Hammer or Focal Access would be my picks, or a DLS Magnesium MW110 if you're handy with MDF and dont mind building a rather complex slot ported box :)
Boring Sig
Blackrazor
Postby Mr.Phreak » Tue Mar 28, 2006 11:20 am
Theres more options than that :P You're just picking the easy ones :D
Mr.Phreak
Postby Blackrazor » Tue Mar 28, 2006 11:29 am
Mr.Phreak wrote:Theres more options than that :P You're just picking the easy ones :D
Not unless you're a dwarf and can rebuild your kickpanels and pedal locations, or mount them atop the engine bay :P
Boring Sig
Blackrazor
Postby Mr.Phreak » Tue Mar 28, 2006 11:34 am
You know you always wanted to scrap the passengers seat and put the drivers seat in the middle :P
Mr.Phreak
Postby Blackrazor » Tue Mar 28, 2006 12:55 pm
Mr.Phreak wrote:You know you always wanted to scrap the passengers seat and put the drivers seat in the middle :P
Yes, of course, i make a habit of advising people to do DIY car butchering that requires recompliancing just to fit a sub in ;)
Boring Sig
Blackrazor
Postby Alex B » Tue Mar 28, 2006 1:33 pm
Not a big fan of the typr r 10's br?
Postby Blackrazor » Tue Mar 28, 2006 3:05 pm
pyro_sniper2002 wrote:Not a big fan of the typr r 10's br?
No, because a RE 10" is about the same performance at less cost, and less mounting depth, and a Rainbow Hammer 10" is the same price but is sonically on another planet. Good luck fitting a Type R behind the seats in an MR2 anyway, thanks to the ludicrously pointless huge basket they attach to them.
Have you seen inside the huge ass cosmetic basket on the type R's? They just have an extra 1.5" of coil former length doing nothing, just so the basket looks impressive :?
Boring Sig
Blackrazor
Postby Mr.Phreak » Tue Mar 28, 2006 4:25 pm
Blackrazor wrote:Yes, of course, i make a habit of advising people to do DIY car butchering that requires recompliancing just to fit a sub in ;)
:lol: Yes Dean
Mr.Phreak
Postby toyonut » Fri Mar 31, 2006 11:56 am
dan, werent you going to mount one inbetween the seats in the space where the cd holder box is. right next to your ear.
toyonut
Postby Blackrazor » Fri Mar 31, 2006 5:11 pm
toyonut wrote:dan, werent you going to mount one inbetween the seats in the space where the cd holder box is. right next to your ear.
I was when i was planning on 8's, but we've since come up with some sneakier ideas ;) BTW the 8 wasnt going to play straight into your ear, it would be mounted downfiring inside a box so that the bass flanged out behind the back seats :)
Boring Sig
Blackrazor
