TRD HEAD GASKET Qs
TRD HEAD GASKET Qs
Postby FLAWLES » Wed Mar 29, 2006 2:29 pm
just a small weee little question here
when you come to fit one of these is it wise to skim " plane " the cyl head a wee bit?
or can you just fit them and be done with it
also can someone please tell me the advantages of having one in a 4agze
chur
FLAWLES
Postby Jebus » Wed Mar 29, 2006 2:53 pm
An alloy head should always be skimmed once its untorqued from the block.
Jebus
Postby blackmk3 » Wed Mar 29, 2006 8:48 pm
well there wouldnt be any advantage unless more reliability itd just change your compression ratio. and yes you shd have you head and block shimmed so there is a perfect flat surface for the head gasket to seal on as metal head gaskets dont flex a bit to take up the discrematies in the sealing surfaces
do some research its almost everyware 8)
Mk3 MA70 Supra
blackmk3
Postby Bazda » Wed Mar 29, 2006 11:03 pm
you will need to get a special grind done on the block, a very fine one compared to the normal grind they usually do.
If the head hasnt been over heated it shoudl be find to use it as it is, just get out the scraper and clean it up mint.
also you wana use that headgasket copper spray before putting the head gasket on.
Postby Mr Revhead » Wed Mar 29, 2006 11:06 pm
and advantages are raised compression, and higher resistance to blowen head gaskets
IF the right mods are made to take advantage of it
also can be reused if in good condition, but for the price ou may as well buy another
Postby CAMB01 » Thu Mar 30, 2006 11:05 am
Would it be absolutely neccessary to spray the gasket with coppercoat?
As i am going to use one on my engine.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby 85AW20v » Thu Mar 30, 2006 1:11 pm
I didn't spray mine, the compression is up a bit and haven't had any problems and I only use the car for racing so its gets a pretty hard time.
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot] and 12 guests
