Ae86 Pre/Post facelift Axles Question
Postby beeker » Tue Mar 28, 2006 7:32 am
The sizes are:
Early (1984-85) AE86 axle size is 24.06mm,
Late (1986-87) AE86 Axle size is 25.30mm;
If my axle/diff housing is an 'Early' one, can i install a facelift 'Late' axle into it ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby nzae86 » Tue Mar 28, 2006 8:04 am
The short answer is no
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby Drifter4ag » Tue Mar 28, 2006 10:10 am
they will fit in the housing but you will require a facelift diff head or TRDLSD
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby beeker » Tue Mar 28, 2006 4:29 pm
Drifter4ag wrote:they will fit in the housing but you will require a facelift diff head or TRDLSD
I have a TRD LSD. So all looks good then.
Next question. I was told you need to cut down the std Axle when you install a TRD LSD. Correct ??
To give you some background, im unsure if my axle is the early or late (have yet to remove and measure). I'll look to buy a couple of new ones as proactive maintenance, and want to get the stronger one, and also understand whats involved (cut down for lsd etc).
06 RS4 Avant
beeker
Postby Drifter4ag » Tue Mar 28, 2006 4:41 pm
sorry i didnt explain well enough ...
you require Late model TRD LSD not early model
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby beeker » Tue Mar 28, 2006 8:16 pm
got it. gotta stick to whatever edition i have then.
Look like i'll have to pull it out to check prior to ordering.
thx guys.
06 RS4 Avant
beeker
Postby Mr Revhead » Fri Mar 31, 2006 10:53 pm
yep early and late
and with the TRD lsd you dont need to trim the axles
Postby Stealer Of Souls » Sun Apr 02, 2006 4:18 pm
Hey. Is it possible to convert an early model diff to late model diff?
Buy a head or LSD, change axles, etc?
'86 AE85.5 Levin
Stealer Of Souls
Postby Drifter4ag » Sun Apr 02, 2006 8:33 pm
yes ..
buy the TRD late model head.
Locate some axles
when i did mine one axle was too long ... dunno if they are all like that.. i just chopped a couple o mm off it .. right hand side it was.
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Stealer Of Souls » Tue Apr 04, 2006 12:32 pm
Drifter4ag wrote:yes ..
Locate some axles
Ah rats. Now I wished I'd know this before. I would've done this instead of buying an LSD to fit the early model I've got...
Oh well.. Maybe in the future...
What sort of power can the bigger axles handle? Or is it much the same as the early model, around 200ps?
'86 AE85.5 Levin
Stealer Of Souls
Postby Stealer Of Souls » Fri Apr 07, 2006 9:28 am
Anyone know the answer?
'86 AE85.5 Levin
Stealer Of Souls
Postby NA Drifter » Sun Apr 09, 2006 1:13 am
Mr Revhead wrote:yep early and late
I installed a TRD LSD on my AE86 (early model) and no trimming needed. everything bolts and fit on fine...
Keith
NA Drifter
Postby Drifter4ag » Sun Apr 09, 2006 10:37 am
in the D1GP 03/04 season there was a turbo AE86 Trueno - Up garage sponsored - 300hp + 50shot of nos ... this was running late model diff & axles .. it was later changed to IRS G series .. they never show how many things they break but i guess it was every now and then.. probably ok when moving but i wouldnt wanna do too many burnouts if you have alot of grip or tramp
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Stealer Of Souls » Sun Apr 09, 2006 7:50 pm
Drifter4ag wrote:in the D1GP 03/04 season there was a turbo AE86 Trueno - Up garage sponsored - 300hp + 50shot of nos ... this was running late model diff & axles .. it was later changed to IRS G series .. they never show how many things they break but i guess it was every now and then.. probably ok when moving but i wouldnt wanna do too many burnouts if you have alot of grip or tramp
Hmm.. So the late model axles are probably a fair chunk tougher...
'86 AE85.5 Levin
Stealer Of Souls
Postby rollaholic » Sun Aug 19, 2007 10:21 am
sorry to revive such an old thread, but where on the axle do you measure to determine its size? across the splines?
Postby Mr Revhead » Sun Aug 19, 2007 11:17 am
theres a page somewhere thats got measurments etc. but i cant find it...
its saved on my work pc
so, if this isnt of any use ill post the other up tomorow
Postby Stealer Of Souls » Mon Aug 20, 2007 9:34 am
rollaholic wrote:sorry to revive such an old thread, but where on the axle do you measure to determine its size? across the splines?
90% sure it's the shaft size, not the splines.
'86 AE85.5 Levin
Stealer Of Souls
Postby rollaholic » Mon Aug 20, 2007 6:46 pm
revvys link seems to indicate its the splines
my measurements yesterday would bear this out, but i could be wrong.
