Compession test
Compession test
Postby trueno_20v » Wed Apr 12, 2006 7:12 pm
Done a compression test on my silvertop 4age today and got:
160 150 160 160 psi
sound right??
i wound it over about 4 times maybe it wasnt enough?
ADMIN EDIT: signature too large
trueno_20v
Postby Jebus » Wed Apr 12, 2006 7:35 pm
Pretty good :D
Jebus
Postby matt9ball » Wed Apr 12, 2006 8:28 pm
i got 175 180 175 170
matt9ball
Postby matt9ball » Wed Apr 12, 2006 8:31 pm
sorry just checked i actually got 170 175 185 185 psi
matt9ball
Postby Malcolm » Wed Apr 12, 2006 8:36 pm
main thing you're looking for is variation, they should all be within about 5% of each other, 5% of 160 is 8, so your minimum should be 152, I'd say you're probably fine, might have slightly worn rings or maybe just did a bad test. I wouldn't be concerned unless you're having overheating problems
Postby AE85coupe » Wed Apr 12, 2006 9:36 pm
wow thats really interesting, my smallport has 250psi across all cylinders
surprises me how much more pressure i seem to have
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Punter » Wed Apr 12, 2006 9:40 pm
AE85coupe wrote:wow thats really interesting, my smallport has 250psi across all cylinders
It can vary hugely, ie throttle open or closed, cam overlaps/timing etc. etc. Infact 4afes will sometimes test higher than 4ages.
Punter
Postby AE85coupe » Wed Apr 12, 2006 9:49 pm
yeah that makes sense, i wonder what smallports usual compression is
Details of car here
AE85coupe
Postby trueno_20v » Wed Apr 12, 2006 10:14 pm
well i done mine with open throttle..
trueno_20v
Postby craigt » Thu Apr 13, 2006 11:39 pm
Actual readings between different gauges cant be compared. They all read differently, whether its because of design or gauge calibration, I dont know.
Compression tests are only useful in comparing the readings between cylinders.
I actually quite like leakdown tests but they are a bit more time consuming to do.
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby CAMB01 » Sat Apr 15, 2006 7:03 pm
i have 180psi across the cylinders on my GZE
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
