EVLGTZ wrote:yeah you should be sweet as.
I use to run 14psi with a td05 on the std ecu and fueling and had no probs
Bazda wrote:I checked it on the dyno also and when the car was rich (about 10.9:1) it would read on the rich side of the scale and when it was normal (12.0-12.5) it would read near the middle of the scale.
peas wrote:Are there any injectors that will sort out high boost leaning out issues? I was looking at 15-16psi on my TD05. I was hoping that some injectors from another model would be a simple enough fit and that the factory ECU could run them. Ive been told that the factory cut is at 18psi on the ECU?? Obviously the rest of the fuel system wouldnt handle that but a Supra (more "advice"?) fuel pump and bigger injectors...?
Users browsing this forum: Google [Bot] and 29 guests
