Cambelt tensioner
Cambelt tensioner
Postby trueno_20v » Sat Apr 15, 2006 11:56 am
im changing my cambelt on my silvertop, ive got everything off easy as but the bolt that holds the tensioner on wont come undone ive broken a couple of sockets and its now rounded the head on it and i dont know how im gonna get it off? any ideas?
ADMIN EDIT: signature too large
trueno_20v
Postby CAMB01 » Sat Apr 15, 2006 11:58 am
Hit the head of the bolt with a hammer a few times then try agian.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Sat Apr 15, 2006 12:03 pm
obvious, but crc?
good luck
Postby Ae92typeX » Sat Apr 15, 2006 12:31 pm
maybe invest in some better sockets in the future also. I gave all my sets hell, and mis-use them for all sorts of things, but have never broken one.
if the crc or hammer does not work, file down to the next size socket first. if still not work you could weld something on for leaverage, or even grind off heads, remove tensioner and tackle it then with a little more room.
Ae92typeX
Postby 20v_rollaboy » Sat Apr 15, 2006 12:39 pm
Ae92typeX wrote:or even grind off heads, remove tensioner and tackle it then with a little more room.
Exactly what I was thinking. Be careful the bolt dosnt break off, leaving the thread in the block, or rather the housing
20v_rollaboy
Postby AceSniper » Sat Apr 15, 2006 3:27 pm
if you have a bolt to replace it (prolly need to now its rounded...
grind/cut the head off it then slide the tentioner off... with out the pressure of the tentioner there you will almost be able to undo it by hand or a pair of vice grips... sounds abit butchery but it works if nothing else does
AceSniper
Postby trueno_20v » Sat Apr 15, 2006 5:36 pm
yea ended up grinding the head off, undone the rest of the bolt by hand, brought a new tensioner and its all back on sweet as
trueno_20v
Postby RickGT » Mon Apr 17, 2006 9:12 am
nut f&*kers work really well, a tip for the future
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby trueno_20v » Mon Apr 17, 2006 11:47 am
RickGT wrote:nut f&*kers work really well, a tip for the future
vicegrips??
trueno_20v
Postby bluemaumau » Mon Apr 17, 2006 1:51 pm
yea wats that?
Postby CAMB01 » Mon Apr 17, 2006 6:25 pm
yea wats that?
POLYGRIPS
CAMB01
Postby trueno_20v » Mon Apr 17, 2006 7:05 pm
CAMB01 wrote:
yea wats that?
POLYGRIPS
lol polly grips arnt the right things to use even VICEGRIPS didnt get it off..
trueno_20v
Postby kingcorolla » Mon Apr 17, 2006 9:14 pm
some polygrips will out-grip vice grips like knipex theve worked for me on more than one occasion
1983 Carina AA63 4age
kingcorolla
Re: Cambelt tensioner
Postby Crucible » Mon Apr 17, 2006 9:29 pm
trueno_20v wrote:im changing my cambelt on my silvertop, ive got everything off easy as but the bolt that holds the tensioner on wont come undone ive broken a couple of sockets
Invest in a decent 3/8 set, go for 6point sockets (less chance of slipping), I cant imagine anything worse than tools not doing the job - instant loss of interest!
tnt
Crucible
Real Life Mechanic
