So yea new springs......
Postby RickGT » Sun Apr 16, 2006 11:37 am
yea i duno i will get something done about swaybars, my next 2 problems are ground clearance springs are 40mm drop and its too low so i need something thats 30mm exactly or ill just get 50 series tyres, and yea now with my new mags they scrape on the lip of the guard, how much to get them rolled or is there an easier way?
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby Caveman » Sun Apr 16, 2006 2:17 pm
Its about $300 to get gaurds rolled from a panel beater. You can get it done for free if you have a mate with the tool 8) Probably best to get it done properly though.
TRD is a 30mm drop and IIRC king low is around 35mm.
On the note of sway bars, is it possible to bend your own piece of steel into a sway bar. I was going to weld two together but since thats heating the original suspension component thats a cert issue. Next idea for me is just get a 17mm steel bar and bend it into the shape I need :D Would this work?
Caveman
Users browsing this forum: Bing [Bot] and 21 guests
