gtz oversized boost pulley not raising boost
Postby RAZA » Mon Apr 17, 2006 6:54 pm
Before anyone asks I've searched on this and found bugger all.
I've put an oversized pulley into my ae101 gtz, and found that it has made the boost increase by a pound or two, but not by the 6 or 7 pounds it was suposed to....
Is there something else one must change to alter the boost or do I have an air leak somewhere? I've checked for leaks and can't find anything so I'm hoping there is some other explaination.
If anyone knows that would be mint.
Currently driving:
BMW 135i M
RAZA
Postby aesc » Mon Apr 17, 2006 7:02 pm
You will have to do the ABV mod, do a search and you shall find
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Rick » Mon Apr 17, 2006 7:06 pm
ABV mod below: if you have already done that maybe your supercharger is fu!ked.
http://www.mr2supercharger.com/ABVmods.html
Postby RAZA » Mon Apr 17, 2006 7:08 pm
OK, if you search for ABV mod, you find this load of crap:
http://forums.toyspeed.org.nz/search.php?mode=results
Anyone care to elaborate?
*edit* Cheers rick you posted while i was writing this
Currently driving:
BMW 135i M
RAZA
Postby aesc » Mon Apr 17, 2006 8:47 pm
If you cant figure that link out then try this
viewtopic.php?t=24717&highlight=abv+mod
Remember when searching to put AND between the search words :wink:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby evil_si » Mon Apr 17, 2006 9:15 pm
ok easiest way to do abv mod.
find abv, it is labelled and located behind supercharger.
there is a vacuum hose going to it from one of the vsv's
cut it and plug it, both sides of cut
done.
evil_si
Postby bluemaumau » Mon Apr 17, 2006 11:01 pm
evil_si wrote:ok easiest way to do abv mod.
done.
i havnt done it, but i was gonna do it to the gze when its in, i thort you had to plug one line and t piece the other half into another? :?
Postby RAZA » Tue Apr 18, 2006 7:44 pm
Thanks guys, all taken care of and working well :D
Currently driving:
BMW 135i M
RAZA
Postby Rick » Tue Apr 18, 2006 9:58 pm
RAZA wrote:Thanks guys, all taken care of and working well :D
So you did the abv modd then??
Postby RAZA » Wed Apr 19, 2006 1:18 pm
Yep, did the abv mod, now making about 13psi :)
Currently driving:
BMW 135i M
RAZA
