I've done some thinking about why some engines run a bearing or throw a rod when low octane fuel is used
My personal High vs Low Octane theory (and how it relates to dead engines):
Part One...
Most ecu's will retard the timing when knock occurs. However, it must the take the ecu some period of time to detect the knock and retard the timing.
If the engine does 10 revolutions before the ecu acts, a very tiny bit of damage might occur. If this happens once every time you drive your car the damage will accumulate and might eventually lead to a premature failure of the engine.
Part Two...
Many modern engines are built with a high compression ratio. Often this compression ratio is too high for the fuel that is recommended by the factory. The factory does this deliberately because...
The high compression gives low fuel consumption when the car is cruising, this makes the car more economical. If higher power is used the ecu is programmed to either retard the timing at higher power settings OR the ecu retards the timing when it detects knock OR both.
If it waits for knock to be detected then we might get the problem I mention in part one of my theory.
Comments please (please think before you post... carefully read everything I've written first).
Ken
Hamilton
021 408 863
