by slighty_sykotic » Tue Apr 18, 2006 9:24 pm
When you take it off chuck a straight edge across the block and head (after you clean ALL the shit off).
If you can't see ANY gaps under the straight edge, then just slap it back together.
(this is of course only on a motor you don't care about, such as this 4k, should be ok tho, if not, you will only have wasted a few hours and a head gasket).
--Sykotic
