Adydas wrote:So when do you need to resort to a wire brush? is it based on look? or material your doing up?
Grrrrrrr! wrote:depends how smooth it is to start with.. if it feels smooth to your finger then wire brush/polishing compound is the go.. but if its metal with a slightly rougher texture your are going to need to start of with sandpaper.. wet'n'dry working down to the finer stuff.. at least down to an 800 grit if you want a good shine.. down to a 1200 or even finer if you want that mirror finish. and yes.. it is very time consuming.. power tools and airtools are your friends!
Mr XXX wrote:yeah I thought auto sol, but in all honesty the mothers alloy polish appers to work just the same, and the mother stuff is cheaper.
Allan
Users browsing this forum: Bing [Bot] and 31 guests
