HRT wrote:Few 7Ks around, workmate is just in the process of buying one to turbo in his KE20.
vhpacer wrote:A 3t from a corona is a good option. Fairly easy to fit, and with some twin carbs you'll have a fun wee car for bugger all $$.
Surely someone will be able to knock up some mounts and a crossmember for cheap. I also heard that you can use some factory mounts and crossmember, dunno what they are though.
isn't the 7K too tall for some installations i.e kp starlets and some ke corollas??mr pad wrote:7k done up (turbo'd) or even worked with cams etc would be damn cool. Not many of them around and yeah, bit different from your average 4age etc...
Have driven on (in newer 1996 hi-ace.. or town-ace.. dont remember) and the difference between a 4k, or even 5k, was quite a bit, heaps more torque, and still revved its titties off when cold![]()
GOOD FOR DRIFTS AU.
