NZJester wrote:When I emailed the LTSA about this they said...info@landtransport.govt.nz wrote:I have been advised by our Vehicle Certification Unit (VCU) you can remove the seats if the removal is permanent. It is ok to remove any seat from a vehicle except the drivers seat and so long as the seatbelt for that seat is removed it won't affect the safety inspection (WOF) being issued.
1998 wrote:AFAIK you just need to register it as a two seater. All the rear seat mounts and seatbelt mounts need to be removed
Distrb wrote:1998 wrote:AFAIK you just need to register it as a two seater. All the rear seat mounts and seatbelt mounts need to be removed
How the heck do you register something as a 2 seater? coz i cannot for the life of me find anything on the rego forms about that under the vehicle type. Sounds like a complete load of heresay and urban myth if you ask me
pc wrote:Register as two seater = Dogs Bollocks.
Distrb wrote:If you want to use 2 fixed back seats, you can* devise a tilt type mechanisim (like they used to have in the old mini's etc... to allow the seat to be moved in such a way that passengers can exit the vehicle.
stephen bedford wrote:what if i had fixed position drivers seat and then reclinable front pasangers, does this get around the if i crash the rear people can get out problem
or is it best i phone ltsa tomorow and see what answers i get,
B1NZ wrote:shouldnt be too hard, its called a Hinge
But the minis had 1/2 size seats, ie. no headrests so they could tilt right over, most seats these days would be too big to do that without hitting the roof?
Distrb wrote:stephen bedford wrote:what if i had fixed position drivers seat and then reclinable front pasangers, does this get around the if i crash the rear people can get out problem
yes it doesB1NZ wrote:shouldnt be too hard, its called a Hinge
Ka pai, a hinge you could use... but like you say the seats these days are too tall, so it needs to be more complex than just a simple hinge
iv seen that happen in a truck when the cabin wasn't bolted shut and the driver hit the brakesLoudtoy wrote:just i have visions of standing on the stop pedal going down a steep hill and giving your passenger a concussion from hitting the dash with his forehead
Loudtoy wrote:Didn't the ones in the mini's ock down in place and you had to press a leaver of some kind to stop them rolling forwards, just i have visions of standing on the stop pedal going down a steep hill and giving your passenger a concussion from hitting the dash with his forehead
Distrb wrote:How the heck do you register something as a 2 seater? coz i cannot for the life of me find anything on the rego forms about that under the vehicle type. Sounds like a complete load of heresay and urban myth if you ask me
