stupid, quick question
Postby AE91Sprinter » Fri Apr 21, 2006 2:24 pm
which cyl is number one on a 5afe? closest to the belts/cambelt cover, or the distributor end?
currently the one closest to the dizzy is set as number one (as been since i owned it)... is this right? all info points to the front that ive seen...
cars got some issues, but i dont want to be pissing around with the dizzy if i dont have to...
AE91Sprinter
Postby gepsk8 » Fri Apr 21, 2006 3:01 pm
one is the closet to the front. eg, cambelt, fanbelt end.
gepsk8
Postby AE91Sprinter » Fri Apr 21, 2006 3:02 pm
how the hell does my car run.... lol.
Ill try redoing the dizzy and seeing what happens. Cheers mate :)
edit - aftermarket cap labelled wrongly; however, a bit of pissing around has made it run soooo much better... crazy!
AE91Sprinter
Postby solberg Fan » Fri Apr 21, 2006 10:04 pm
If you lined up the timing marks on the pully to TDC and took the dizzy cap off to see where the rotor was pointing it would be pointing either #4 or #1 cyl.
Im gessing this is what you have done? Turn the crank over one more time and the rotor will be on number 1. this is because the dizzy only turns half the speed of the crank shaft.
Or was it just the aftermarket cap that was labeled wrong?
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby AE91Sprinter » Sat Apr 22, 2006 12:10 am
nah, just the cap. I lined up the cams so it was on #1 TDC, and it was on the top of the compression stroke - #3 would be just starting on the inlet stroke, so it wasnt 180 degrees out.
I think some pissing around reseating relays + cleaning connections, along with a better timing helped a bit.
AE91Sprinter
