The right angle speedo sender attached to the gearbox (e51) seems to have seized. Is there some trick to making it turn while out of the car, or should it just turn easily?
Also are there any direct replacement senders from other gearboxes? (things with 3sge's?) I imagine trying to find another gze levin at pick-a-part will be a waste of time.
