NEED HELP~~~~~~~~~~~~~~~~~
Postby Superbanana » Mon Apr 24, 2006 9:47 pm
hey, guys just wanna know how to take off the steering wheel off my 1996 Levin, tyring to put a new one on, but someone told me it is dangerous, coz it has airbag, and also it might fail the WOF, but I don't see any lairbag light on my dashboard!!!
so anyone can give me an answer??? Thanks!!!
Superbanana
Postby Dell'Orto » Mon Apr 24, 2006 10:17 pm
If it is an airbag steering wheel (will say something along the lines of SRS on the wheel) you cant take it off. A. its pretty dangerous, as the propellant charge is much like a shotgun cartridge and can do the same sort of damage, B. its removing a part of the "necessary" safety features and will make you fail warrants.
Postby NILPSI » Tue Apr 25, 2006 10:14 am
If its like mine then it will have a mechanical airbag in it, in which case the light will only come on if there is a fault with the airbag, like say if it is removed, there is a light on the dash by the fuel gauge but it isnt very easy to see until it lights up
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby BZG_UNIT » Tue Apr 25, 2006 11:24 am
i got a 97 trueno bro.. you cant/shouldnt take the steering wheel off. :D
BZG_UNIT
Postby Superbanana » Thu Apr 27, 2006 3:34 pm
I really wants that steeling wheel off, has anyone here done that before???????
Please....................................
Superbanana
Postby dotdog » Thu Apr 27, 2006 6:36 pm
If its a airbag steering wheel, dont pull it off, you wont pass a wof without it and id say your insurance wont pay out if its missing
dotdog
Postby astrae » Thu Apr 27, 2006 6:51 pm
this should be in the Tech section.
Ask there
astrae
Postby Dell'Orto » Thu Apr 27, 2006 6:56 pm
Doesnt really matter, answers will be the same still.
Postby Superbanana » Fri May 12, 2006 6:22 pm
Haha, finally Got my Steeling wheel off, Air bag was fine. Nothing has been damaged! Everything works fine now.
Got my momo one in now, looks great.
the only pity thing is the horn doesn't work properly.
anyway, that wasn't too bad to take it off. thanks anyway, guys!
Superbanana
Postby dotdog » Fri May 12, 2006 6:26 pm
is ya airbag light stuck on? cause if it is no more wof, and if you crash no insurance
dotdog
Postby NILPSI » Fri May 12, 2006 9:23 pm
Also i would recommend that you remove the sun visor with the SRS writen on it, If you do go for a warrant if they decide to look at it and see that its meant to have an airbag then you will fail and have to put it back in to get a warrant
NILPSI
Postby bluemaumau » Fri May 12, 2006 9:34 pm
you will also fail on having no horn. i think
Postby flat_0ut » Fri May 12, 2006 10:14 pm
bluemaumau wrote:you will also fail on having no horn. i think
true true
flat_0ut
Postby BlakJak » Mon May 15, 2006 9:26 pm
Right, so despite all advice to the contrary you have gone ahead and performed an illegal modification to your car.
It is illegal to remove an Airbag. Nuff said.
Not having a Horn is also illegal, but even if you fix that, your car _is_ illegal. If the WOF techy is on the ball and realises your car comes with Airbags OEM, you're stuffed - you probably need certification now.
BlakJak
Postby NILPSI » Mon May 15, 2006 10:54 pm
Question for the people on here who are in the know,
If your vehicle comes with an airbag from factory, are you allowed to remove it and get a cert, or is it illegal even with a cert to remove an airbag?
NILPSI
Postby Mr.Phreak » Mon May 15, 2006 11:00 pm
NILPSI wrote:If your vehicle comes with an airbag from factory, are you allowed to remove it and get a cert
Yup, but you have to remove all the signs that there was an airbag too. As usual with these things, it's best to chat to your local certifier before doing anything.
Mr.Phreak
Postby NILPSI » Tue May 16, 2006 7:11 am
Cheers man
NILPSI
Postby Dell'Orto » Tue May 16, 2006 7:15 pm
AFAIK, its still illegal as the airbag is what the LTSA deemed to be part of the equipment to keep the car up to the frontal impact standards.
Postby Superbanana » Sat May 20, 2006 10:59 am
well, coz at the first hand, my dash board has been modified by previous owner already. and it doesn't have any light on the dash board associated with the air bag. not before, not even after I changed the steering wheel.
but hey, thanks for u guys' advices. anyway, i love my steering wheel......hahahaha!!
Superbanana
Postby Bling » Sun May 21, 2006 6:41 pm
some come with airbags, so dont come with airbags, if no light shows up, doubt there will be any problems with wof or insurance...
but hey what do I know, i'm stuck with airbag, while mate with basically same car has momo :cry:
Return to Palmerston North / Central North Island Region
