I saw this stuff at ripco today that was called metal filler or something similar. Anyone used this?
I've tried some sort of bodyfiller in the past that you had to mix up but I sucked at teh panel work and did a terrible job.
Cool, Yeah I meant just get rust out, by whatever means. where can I pick that fish stuff from?no_8wire wrote:you can sand out rust? I normally just attack it with grinder...then fisholine on the bare metal and 3 days later paint/ start to bog...just normal car bog...
Rick wrote:The best and only real method of stoping rust is to remove it completely by cutting and welding in a new pannel but if that is not possible like in alot of cases then I would recommend Por 15, great stuff.
http://www.por15.com/
sergei wrote:Rick wrote:The best and only real method of stoping rust is to remove it completely by cutting and welding in a new pannel but if that is not possible like in alot of cases then I would recommend Por 15, great stuff.
Where can you get that stuff?
