st206 drive shaft?
st206 drive shaft?
Postby Infinite » Fri Apr 28, 2006 7:08 pm
hey i needa remove my passengers side drive shaft... howto lmao noob
Lots
Infinite
Postby bluemaumau » Fri Apr 28, 2006 8:05 pm
undo clip around cv boot.(both) then slide boot down shaft, then remove clip in inner cv housing, then pull out, depending on the cv there may not even be a clip in the housing, for the hub side its pretty easy surely you can figure that out
