matt dunn wrote:Apparantly fitting a catch can fixes it.
TrouserFxGt wrote:I would imagine that it has some thing to do with the computer not activating the vvt until there is a certain engine coolant temp.
dotdog wrote:mine has only started doing it in the last 5000kms
overkill wrote:coz pressure/volume of oil would be lower when colder.
vvega wrote:id be going the lead/plugs/cap/rotor/coil/ignitor path
typically you have higher cylander pressures when your engine is cold
so is a little harder on your ignition system
v
