exhaust?
exhaust?
Postby Infinite » Wed May 03, 2006 9:07 pm
ok i have got a 3" stainless steel mandrel bent system in the rear of my car front not done yet? whats better stainless or just "normal exhaust pipe"? its going to be runing a 3sgte gen3 very soon :D
Lots
Infinite
Postby crnkin » Wed May 03, 2006 9:31 pm
You sure its stainless? or just that fancy mild steel stuff. (forget what its called).
Stainless is an absolute bitchh to work with compared to mild, and is farken heavy.
The guy at the exhaust shop told me to not mix and match, but spose it doesnt really matter unless its a show car, only thing that happens is if you use two different types of metal they react with each other and rust quicker.
Hope this helps if not a little
deaf_homo "currrently yes"
crnkin
Postby Norty » Fri May 05, 2006 12:27 pm
I would go normal unless you plan to show the underneth off. besides it wont stay nice and stainless like for long once you start pumping that hot hot exhaust fumes thru
Norty
Postby LEV_101 » Fri May 05, 2006 7:31 pm
well ... i would tell you to go Titanium ... :lol:
but not all of us can afford to go that path ...
so i guess stainless steel would be good... cheap and light
LEV_101
Postby flat_0ut » Fri May 05, 2006 7:33 pm
stainless steel for the price :wink:
flat_0ut
Postby Jebus » Fri May 05, 2006 7:44 pm
Youre joking right?
Jebus
Postby AE91Sprinter » Fri May 05, 2006 8:21 pm
I think hes comparing it to titanium.
AE91Sprinter
Postby Caveman » Fri May 05, 2006 10:18 pm
LEV_101 wrote:so i guess stainless steel would be good... cheap and light
BS
the stuff alot of shops use it mild steel with a aluminum coating. Help protect against corrosion.
Mild steel is lighter than stainless.
Caveman
Postby LEV_101 » Sat May 06, 2006 7:18 pm
depends how thick you wanting the stainless to be ... ???
LEV_101
Postby dougsop » Sat May 06, 2006 8:22 pm
HKS slient HI POWER catbak sounds awesome in my ST205 GT4 3sgte :D
dougsop
Postby Infinite » Sun May 07, 2006 8:53 am
ive been told this exhaust isnt nzmade... so i guess its been imported from japan or some thing pitty its on the car now coulda got a picture have check some hks ones out and it does look alot like them tho!
Lots
Infinite
