bleeding abs brakes?
Postby Infinite » Wed May 10, 2006 9:43 am
how do u bleed abs brakes just like normal or more advanced?
Lots
Infinite
Postby TWSTD » Wed May 10, 2006 12:55 pm
just like normal - generally start from the fartest from the master cyl and work towards it.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby kingcorolla » Wed May 10, 2006 1:44 pm
it is 'recommended' you bleed them whist engine running.
1983 Carina AA63 4age
kingcorolla
Postby magweal » Wed May 10, 2006 3:45 pm
i never had a problem bleedin them without the engine running
magweal
Postby RunningRich » Wed May 10, 2006 4:20 pm
My ST205 ABS actuator goes wizzzz when the ignition is turned on. When bled with ignition off (after brake rebuild) I had a spongy pedal. This firmed up when bled with ignition on (wizzzzz...)
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Infinite » Wed May 10, 2006 6:22 pm
ok i will do it with the key on then :)
Lots
Infinite
Postby ollieboy » Wed May 10, 2006 10:26 pm
RunningRich wrote:My ST205 ABS actuator goes wizzzz when the ignition is turned on. When bled with ignition off (after brake rebuild) I had a spongy pedal. This firmed up when bled with ignition on (wizzzzz...)
I read this this arvo and was like oh yeah maybe but then it got me thinking about my dads van and the brakes are hugely spongey. They have been bled alot but they were still spongey so I tried it today with the ignition on and the brakes are like new.
ollieboy
