matt dunn wrote:The main performance reason for fitting a catch can is to prevent the vapours from entering the engine as they cause detonation,
So why fit a can and then run it back into the intake anyway??
Matt
matt dunn wrote:The main performance reason for fitting a catch can is to prevent the vapours from entering the engine as they cause detonation,So why fit a can and then run it back into the intake anyway??Matt
Yep I got given a valve that goes between the hose running from the rocker cover to exhaust, thinking of running one on my ccan but dunno if I really need to?Ako wrote:Don't a lot of the V8 boys run an exhaust valve thingy?
Ako wrote:Well done mark, you've just confused yourself.
sergei wrote:I have an idea of electric vacuum pump sucking it out all the time, but I can't source one... I think it will give good results becuase it will decrease pressure behind the pistons thus increasing pressure difference on power stroke, also it will seal the piston ring better, the oil seals will seal better as well.
Donor wrote:matt dunn wrote:The main performance reason for fitting a catch can is to prevent the vapours from entering the engine as they cause detonation,So why fit a can and then run it back into the intake anyway??Matt
thats what I thought! but all the cans on trademe have two tubes welded to them ........WTF aye? maybe this collects oil mist in the can so reasonably clean air is sucked into the in/man???. Im thinking these are only for n/a motors???
Donor wrote: Do I need to run two lines into a can with a breather or will one be fine? thanks
