T50 fork Spring
T50 fork Spring
Postby repowered » Wed May 10, 2006 5:05 pm
got my t50 for ke30 in all good, jsut runing clutch line. noticed hole in clutch fork near the seat for the slave to sit into, is this for a spring ? my guess is yes.
ill have to make somthing up, doesnt look like theres any hook on Box to hook spring onto though. might have to make somthing up on the underbody.
Rollin!
repowered
Postby AE85coupe » Wed May 10, 2006 6:49 pm
i don't recall there being a spring on t50 clutch fork, at least mine doesn't
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby 2LTR Rona » Wed May 10, 2006 7:41 pm
AE85coupe wrote:i don't recall there being a spring on t50 clutch fork, at least mine doesn't
Same as AE85, I put mine back in about 2 or so weeks ago now and def no spring involved anywhere near the slave
2002 Altezza, 1974 KE25
2LTR Rona
Postby l1ttle_d3vil » Thu May 11, 2006 10:21 am
ive got a spring on my t50/ke35. ive just hooked it around my slave cylinder bleed nipple from memory.
Postby repowered » Thu May 11, 2006 3:38 pm
cheers for that gyus
do those that dont have a spring, cant you remeber if there was a hole for one?
i'll see how it goes without for now.
Rollin!
repowered
Postby repowered » Thu May 11, 2006 3:42 pm
awsome looking 30 also man :) did you get someone to make up that front lip?
Rollin!
repowered
Postby AE85coupe » Thu May 11, 2006 3:54 pm
yeah its my flatmates
yeah his old man just made it out out fibreglass haha
Details of car here
AE85coupe
Postby KinLoud » Thu May 11, 2006 9:20 pm
Yeah - hole, no spring on the couple of T50's I've had in the past.
Ken
hamn
021 408 863
Postby repowered » Sun May 14, 2006 10:05 pm
hehe cool yea had to be custom aye, the japs go rediculas with their front spoilers aye, looks crack up
KinLoud wrote:Yeah - hole, no spring on the couple of T50's I've had in the past.
Ken
hamn
021 408 863
churz for clearign that up fellas
Rollin!
repowered
Postby 2LTR Rona » Sun May 14, 2006 10:53 pm
repowered wrote:do those that dont have a spring, cant you remeber if there was a hole for one?
Can confirm, hole in clutch fork for spring but no spring there, havent had an issue with that set up yet
2LTR Rona
Postby repowered » Mon May 15, 2006 12:12 pm
sweet, thanks
Rollin!
repowered
bleeding clutch
Postby repowered » Thu May 18, 2006 7:53 pm
just got the clutch line all installed and hooked up but...
i filled it up with fluid and bled it through the bleed nipple till all the air was gone then did it up while pedal was flat down. but the pedals soft as hell theres like no resistance pressing the pedal down and only about 10mm of movement in the slave , not sure if there should be more. I reckon its enough to disengage the clutch , but the pedal feels wrong.
ive modded the pedal box so the pedal picks up the clutch master fork, it only pushes clutch fork in about 70% of the full distance it can move in. not sure if that will affect it.
i found a random spring and hooked it up but was bit weak and didnt make a diffrence to the feel of the pedal.
i'll put the shifter on and see if it makes any differnce changing gears (engine not going yet.... rolla on axle stands)
hope all that isnt confusing i got some pics of my pedal box i might post up
Rollin!
repowered
Postby Jazza » Thu May 18, 2006 8:11 pm
Ever snapped a clutch cable? Cos from my minimal knowledge of clutches, thats what it sounds like. Prove me wrong :P
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby repowered » Thu May 18, 2006 9:02 pm
its hydralic sorry
Rollin!
repowered
