Suitable rear brake upgrade for a kp60
Postby ollieboy » Mon May 08, 2006 10:18 pm
Just looking at brakes for my starlet. Is it possible to get good rear brakes without spending too much money? Im upgrading the fronts so I thought I might as well put something decent on the back.
Edit: Is there some that will bolt up straight from another vehicle even?
ollieboy
Postby 2LTR Rona » Mon May 08, 2006 10:22 pm
What do you define as spending too much money?
Personally if I want to go fast then I start at the brakes first, IMO there is no point in going fast if ya cant stop :wink:
What have you upgraded the front to? the back might be suitable if the front has been done as well
2002 Altezza, 1974 KE25
2LTR Rona
Postby ollieboy » Mon May 08, 2006 10:27 pm
I put disks off a 1986 Mark 2 Corona on. They are huge disks about 10cm or so maybe more. (Huge compared to Starlet standard.)
I meant spending too much money as in I would like to get the brakes off an old car that I don't have to spend much on.:oops:
ollieboy
Postby ollieboy » Mon May 08, 2006 10:30 pm
I meant to say brakes are about 10" not cm
ollieboy
Postby mjrstar » Thu May 11, 2006 5:23 pm
i have fitted rx7 calipers and vx landcruser discs. 315mm rotor 22 mm thick.. that should stop it!! cost about $500 for all the bits n pieces including brand new mintex pads and discs.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Dunny » Thu May 11, 2006 11:05 pm
mjrstar wrote:i have fitted rx7 calipers and vx landcruser discs. 315mm rotor 22 mm thick.. that should stop it!! cost about $500 for all the bits n pieces including brand new mintex pads and discs.
You must have slightly bigger wheels than 13"
Dunny
Postby mjrstar » Fri May 12, 2006 8:58 am
yeah it's on 15'' wheels.
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
