Check your fluids ladies and gentlemen!
Postby Quint » Sat May 13, 2006 8:24 pm
All innuindoes aside...
Driving home from auckland today, and the stearing in my GA-70 started getting real heavy, and then twtiching, at first i thought i had blown a tyre and was going to let out a mighty yell. But anyway, pulled over, and couldn't find anything wrong, so u know, wasn't sure what the hell the deal was. Kept going got to a petrol station, checked pressures etc. and clicked onto the fact that my power stearing fluid might be low, baught some automatic trans fluid and dumped that in there and shes working again sweet, but now the system has air bubbles in it (slight twitching), hopefully they'll bleed out over night.
So basically, the moral of the story is, don't just check your oil levels, check Power stearing, brake fluid, Trans (if ur an auto) and water.
From,
Someone who never considered their P/S running out of fluid :)
P.S. it is auto fluid you use isn't it? couldn't remember if it was manual or automatic fluid. Oh, and the systems probably leaking somewhere, So its going to be line tracking day for me tommorow, YAY!.
Quint
Postby deaf_rattle » Sat May 13, 2006 8:32 pm
hey
yeah atf is the same as ps fluid
so no worries there.
might want to find out where its leaking from tho.. check the connections to the rack, i have seen supras leak there.
Postby crnkin » Sat May 13, 2006 10:20 pm
I think my 4agte is knocking cos i went drifting with out oil on the dipstick... DOH.
Even if you just check your engine oil friends :)
Stupid enzed dodgy useless oil feed builder
deaf_homo "currrently yes"
crnkin
