how much camshafts' oil tolerance do you use to have in your modded engines?
TIA...
Wolf_Tm250 wrote:Hi fivebob!
I put off my cams after 1000 miles of job to adjust the valves clearance, and i found them to be quite... awful...
Not ruined... but they have darker shadows where they turns in the supports...
So i supposed too little oil clearance...
fivebob wrote:Got a photo of them?
Doesn't sound like to little clearance, that should cause the bearing to "pick up" and you'd have a ruined bearing. I suppose if it was just slightly to tight it could cause the oil to overheat, carbonise and leave a mark, but without seeing them it's impossible to say if there's actually anything wrong.
fivebob wrote:
Wolf_Tm250 wrote:Hey mate,
we found an error in Toyota manual, call them !!!![]()
journal oil clearance 0.001"-0.0025" = 0.025mm-0.062mm
fivebob wrote:Wolf_Tm250 wrote:fivebob wrote:
Hey mate,
Indeed it is wrong, strange that the imperial measurement is correct, even though it's made in a country that uses the metric system.
At 0.0025mm clearance it wouldn't last very long before destroying the bearings
Akane wrote:Oh i see, but I didn't know there are bearings in the camshaft journal too, I thought it goes straight to the journal.
Wolf_Tm250 wrote:Let me make a little OT...
I mounted a 2nd egt sensor and the Motec AmpliTCK...
please give me a little little advice on a little fuel compensation map for too high egts
Users browsing this forum: No registered users and 26 guests
