Cleaning up cams.
Cleaning up cams.
Postby Jebus » Mon May 15, 2006 11:43 am
Got some blue top cams, theyre out a gunked up motor and just wanna clean them up like new before I put them in, what can/cant I do to get them clean and shiny.
I have degreaded them, and wiped them down and buffed with a wire wheel real lightly the rough casting between the lobes, so can i go over the lobes lightly with the wire wheel on the bench grinder??
Jebus
Postby sergei » Mon May 15, 2006 11:46 am
I would not go with wire wheel over the lobes, but I have noticed that spray on paint stripper removes sludge really well...
Postby HELBND » Mon May 15, 2006 11:47 am
Brake cleaner works REAL good :)
HELBND
Postby Jebus » Mon May 15, 2006 11:48 am
HELBND wrote:Brake cleaner works REAL good :)
Ah will give that a go, but that wont bring back the underbody of my car will it :lol:
Jebus
Postby Grrrrrrr! » Mon May 15, 2006 11:55 am
CRC Clean-r-Carb is the stuff you want, dissolves all that gunk like you wouldn't beleive. either that or just scrape the worst of it off and put it in ya motor and run a decent brand oil and change it regularly. after 3 or 4 changes that gunge will have come right off.
Grrrrrrr!
Postby HELBND » Mon May 15, 2006 12:07 pm
lol probably not, but if you find any chunks of my driveway in your undercarriage, could i have them back? :lol:
HELBND
