H4H headlight bulbs
H4H headlight bulbs
Postby flat_0ut » Sun May 14, 2006 10:34 pm
anyone know if h4h bulbs would fit an '89 ae92 levin?
flat_0ut
Postby Mr Revhead » Sun May 14, 2006 10:36 pm
h4 is the standard toyota bulb for most models.
and for the corolla
Postby AJz » Mon May 15, 2006 12:41 am
yea i dont think any toyotas use h4h,
those sort of bulbs are in honda civics.
I had vtax :(
AJz
Postby Hybridd » Mon May 15, 2006 10:29 am
Most Toyota vehicles come out with H4 bulbs as standard fitment... 8)
AE92 South African Spec Hatchback
FXGT Wannabe
Hybridd
Postby TWSTD » Mon May 15, 2006 3:33 pm
H4 is not the same as H4H
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby Hybridd » Mon May 15, 2006 3:45 pm
OOPS My Bad...I assumed the reference was to H4 bulbs...Whats the difference by the way between H4 and H4H... :?: 8)
FXGT Wannabe
Hybridd
Postby XERO » Mon May 15, 2006 3:49 pm
Mr Revhead wrote:h4 is the standard toyota bulb for most models.
and for the corolla
Hoorah for being diffrent caldina's use h7's with the black headlights (not sure about the white headlights)and h3's for the drivers 8)
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby flat_0ut » Mon May 15, 2006 5:07 pm
cheers, also anyone know what this sensor (i think) and pipe are and where they go? ( i just put in my pod)
http://i75.photobucket.com/albums/i318/ ... re0010.jpg
flat_0ut
Postby sergei » Mon May 15, 2006 5:11 pm
I think it is for A/C idle up solenoid...
Postby TWSTD » Mon May 15, 2006 7:03 pm
Hybrid-SA wrote:Whats the difference by the way between H4 and H4H... :?: 8)
Whatdya mean whats the difference ??? - take a look at the pics i posted - so you could see the difference!
Click here!
TWSTD
Postby flat_0ut » Tue May 16, 2006 10:49 am
performance wise i think he meant.
flat_0ut
Postby TWSTD » Tue May 16, 2006 1:09 pm
Nothing. Fitment is just that - FITMENT. Its nothing to do with the colour, performance, light output or any other variable.
Click here!
TWSTD
Postby flat_0ut » Tue May 16, 2006 5:22 pm
sergei wrote:I think it is for A/C idle up solenoid...
does it matter if i drive without it? the black tube's sucking in air so im guessing it should be clean air?
flat_0ut
Postby sergei » Tue May 16, 2006 5:28 pm
leaving black tube open will increase the idle speed, you can adjust that back up using screw on the throttle body (with flat screw driver), when you block it with a small bolt...
