problems with the idale
Postby Diverz_Fxgt » Thu May 18, 2006 12:38 am
hi guys. i have 1988 ae92 fxgt. i have problems with my idale droping down to less than 500 rvers every know and then and if i dont keep reverin 2 keep the idale @ 1000 the car switchs off. i have tryd turing it up but i still giving me the same problem. plus my battery power goes down at the same time. any help will be most helpfull. thanks
Diverz_Fxgt
Postby 20v_rollaboy » Thu May 18, 2006 1:47 am
Does it go straight down or bounce up and down and then die? Have you checked for water leaks?
And what do ya mean by the battery power goes down at the same time?
20v_rollaboy
Postby MrOizo » Thu May 18, 2006 9:24 am
could be something like alternator not supplying enough power to the fuel pump or something?
are you jump starting it initially?
MrOizo
Toyspeed Legend
Postby mr pad » Thu May 18, 2006 9:50 am
sounds like it could be the alternator. Is your battery going flat? having trouble starting?
idle. idle.. IDLE. :)
mr pad
Postby Diverz_Fxgt » Thu May 18, 2006 6:06 pm
20v_rollaboy wrote:Does it go straight down or bounce up and down and then die? Have you checked for water leaks?
ya it bounces up and down. dont have any water leaks had my cooling system and the head gasket changed about 6 months ago. for the battery it lose power. i have a factory voltmeter on the dash. the needle on the voltmeter points just below the 18v.
Diverz_Fxgt
Postby 20v_rollaboy » Thu May 18, 2006 7:06 pm
Charging should only be about 14v shouldnt it?
20v_rollaboy
Postby Diverz_Fxgt » Sat May 20, 2006 1:32 am
MrOizo wrote:could be something like alternator not supplying enough power to the fuel pump or something?
i dnt jump start it but my start motor is playin up so im goin 2 change it. how do u check if u have problems with the fuel pump.
thanks guys for all ur help.
Diverz_Fxgt
Postby solberg Fan » Sat May 20, 2006 2:46 am
If you mean the voltmeter reads low at 500rpm, thats prety normal. They need a few revs before they start to work. It should read between 13.5 - 14.5V at about 2000 rpm.
Im not sure what engine you have but i have the same prooblem with my bmw at idle. I know (in my case) its the idle control valve at fault but they want an arm and a leg for a new one.
Maybe give your throttle body a clean out.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby NooDleS » Tue May 23, 2006 4:14 am
Ok, a few other things you might want to give a try looking at...
1). IACV (Idle solenoid)
2). Fuel pump filter
3). A Dodgy earth
4). Faulty thermostat
5). Spray some carb cleaner into the TB
In my old Fiat Bravo, believe it or not, i spent hundreds trying to fix this and it ended up being faulty wiring for the immobiliser.
Hope this helps
Arriving August 22nd to a Town Near You
NooDleS
Postby Diverz_Fxgt » Thu May 25, 2006 12:55 am
thanks guys 4 ur help.
Diverz_Fxgt
Postby NooDleS » Fri May 26, 2006 12:38 am
have you got it sorted?
NooDleS
Postby Diverz_Fxgt » Sat May 27, 2006 2:10 am
NooDleS wrote:have you got it sorted?
na not yet being very buzy with my studyz got exams cmin up. i will try all ur methods in the weekend. thanks for ur help.
Diverz_Fxgt
Postby deaf_rattle » Sat May 27, 2006 10:20 am
let me know how you get on, my fxgt is doin the same thing.
im lazy so it will probably just keep doin that for ages :lol:
im going to look at the intake piping and try bleeding the coolant system again. failing that some more earths
