best turbo head what do you think
Postby trdfxgt » Thu May 18, 2006 9:27 am
hi i have both a small port 16v head and a big port 16v head im trying to decide which im better to use the block is a super charged one so it has the oil drain tick for the small port head. also there is the tvis which from what i can see would remove most of the benifit of the big ports ?? i also have both inlet manifolds so again im unsure which will be best to use any thoughts ???
to add this is not about all out power i want good power but with maximum reliabilty i want to have around about 200 hp i have a good turbo and running the blue cams in which ever head i end up useing
trdfxgt
Postby Mr Revhead » Thu May 18, 2006 9:35 am
whats the engine for?
rest of engine specs?
how boost you aiming for?
Postby trdfxgt » Thu May 18, 2006 9:40 am
engine is for racing so it will get worked hard but not reved above standed
trdfxgt
Postby Stealer Of Souls » Thu May 18, 2006 9:43 am
I would have to vote for big port with no TVIS.
'86 AE85.5 Levin
Stealer Of Souls
Postby trdfxgt » Thu May 18, 2006 9:45 am
how do i remove the tvis and if i do the inlet manifold still has 8 small holes ???
trdfxgt
Postby Drifter4ag » Thu May 18, 2006 10:41 am
small port head gets my vote
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby EVLGTZ » Thu May 18, 2006 10:48 am
Small port head gets my vote as well.
Only 200hp sounds like low boost application but since for racing will be hard worker etc
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby trdfxgt » Thu May 18, 2006 11:40 am
200 hp @ the wheels if i can get it to much hp in a front drive means trac loss and with trac goes time
trdfxgt
Postby crnkin » Thu May 18, 2006 1:29 pm
Definitely smallport, have a look at some of drifter 4ag's set ups on garage dori, smallport for sure.
deaf_homo "currrently yes"
crnkin
Postby Bazda » Thu May 18, 2006 4:19 pm
big port :D
Postby Drifter4ag » Thu May 18, 2006 4:41 pm
yeah .. for 200hp at wheels stock redtop head would be awesome.
Bluetop cams
and not even that much boost
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Stealer Of Souls » Thu May 18, 2006 5:25 pm
Hmm...
I'm confused by the responses. Why do people say smallport head?
Surely if it's a racing engine you wanna optimise flows and efficiencies in the upper RPM band.
Max cylinder filling at upper RPM. So bigger ports for reduced pressure drop across ports/head?
'86 AE85.5 Levin
Stealer Of Souls
Postby sergei » Thu May 18, 2006 5:36 pm
Bigger ports actually slow down the charge, the benefit of speed is that air has got inertia and with higher velocity more air will enter, thus taking advantage of longer duration (remeber the valve is still open when piston starts compressing the air, to allow more air to enter due it's inertia). Even with turbo the flow of air is not continous, so wave physics plays more than people give credit to.
Postby crnkin » Thu May 18, 2006 6:21 pm
smallport - smallport
SMALLPORT
crnkin
Postby EVLGTZ » Thu May 18, 2006 7:40 pm
quite simple really aint it
EVLGTZ
EVLGTZ
Postby crnkin » Thu May 18, 2006 8:37 pm
SMALLPORT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
crnkin
heh
Postby ezy10s » Thu May 18, 2006 9:04 pm
small port will keep the velocity up in the port at lower rpm giving better responce.
as the engine is only 1600cc there is no real advantage to using the big port over the small port at all
Member #244
Gone fishing until further notice
ezy10s
Postby crnkin » Thu May 18, 2006 10:24 pm
SMAAAAAAAAAAAAAAAAALLLLLLLLLLLPORTTTTTTTTTTTTT
crnkin
Postby Mr Revhead » Thu May 18, 2006 11:19 pm
bah use the big port, methanol, 45psi and aim for 600hp :P
Postby Drifter4ag » Thu May 18, 2006 11:24 pm
heres the bizzo ...
same setup
9.2:1 engine 14psi big port head was 176kw @wheels
same engine 8.0:1 small port head 183kw @wheels
nuff said
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
