bluemaumau wrote:power built
just missed out on the promotion!
$200 - 1/2 set
with lifetime warrenty
Mmm, Boost wrote: though again mechanics can wreck them pretty easily
Quint wrote:... Looking at a socket set (possibly 24 piece, imperial and metric) From about 6mm to uhh say 24mm and imperial with what ever their numbers are... Also would want a set of spanners with a box end ranging through the same sizes.
HRT wrote:
If you're getting a 1/2 set then you'll probably want to go up to a 32mm as that will cover Toyota CV nuts (not all).
