power steering heavy
Postby mjrstar » Thu May 18, 2006 5:03 pm
My g/f has an ae111 corolla and the steering has got heavy lately i have checked the usual stuff like belts, power steer fluid, tyre pressure and there is no abnormal noise from the pump either.. but the stering is still heavy. does anyone know if there is a filter or something that could be blocked that could cause this problem??
suggestions welcome
Thanks.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby solberg Fan » Fri May 19, 2006 1:05 am
The only thing that i can quickly think off is a crushed pipe??? :?:
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby cespenar » Fri May 19, 2006 1:45 pm
Just to poach thread my PS groans when turning at low speed, usually but not always after it's been raining, any ideas?
cespenar
Postby Crucible » Fri May 19, 2006 6:43 pm
mjrstar wrote:My g/f has an ae111 corolla and the steering has got heavy lately i have checked the usual stuff like belts, power steer fluid, tyre pressure and there is no abnormal noise from the pump either.. but the stering is still heavy. does anyone know if there is a filter or something that could be blocked that could cause this problem??
suggestions welcome
Thanks.
Pop off the tierods and spin the struts by hand to make sure the balljoints and strut mounts are ok, if fine turn the rack lock to lock to make sure its not binding up. If ok then the pump may need attention.
cespenar wrote:Just to poach thread my PS groans when turning at low speed, usually but not always after it's been raining, any ideas?
If the fluid level is ok then normally this points to a faulty pump.
Crucible
Real Life Mechanic
Postby mjrstar » Thu May 25, 2006 11:28 am
cheers for that guys. i guess that's an easy way to see if it's a mechanical binding or a tired pump..
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 5 guests
