gt-t boosting funny?
Postby cynakyl » Thu May 18, 2006 7:13 pm
Hey all, my 97 gt-t seems to be playing up a little but i've never had a turbo car before so i not too sure what it could be. i put a boost gauge in it a month ago and it always boosted to about 12.5 psi even under hard acceleration. i've since come to assume this is the factory limit. but in the last couple of weeks i've noticed that under hard acceleration it now goes up to 14-15 and then drops down to 12ish. anyone have any idea what could be causing this and if it's bad? ( i assume it is). also if it a problem how would i go about fixing it.
Driving a honda is like being in the special olympics. Even if you win, you're still retarded...
cynakyl
Postby sergei » Fri May 19, 2006 12:22 am
I always assumed that GTT are boosting arround 1bar (14.5psi) from factory..
Postby Punter » Fri May 19, 2006 10:09 am
Yea in my mates one its 12~13psi in 1st and 2nd 13~14psi in 3rd and 4th.
Punter
Postby Santa'sBoostinSleigh » Fri May 19, 2006 11:38 am
yup thats pretty normal, mine does it too
depends on plenty of things such as load, fuel, intake temps etc
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby cynakyl » Fri May 19, 2006 7:05 pm
so it normal for it to fluctuate a bit before settling at one point? ok that good, here i was thinking there was something wrong with it.
thanks guys.
cynakyl
Postby Wildcard » Fri May 19, 2006 7:11 pm
a 10c drop in temperature equals ~1psi increase in boost to me....
Wildcard
Toyspeed Founder
Postby mr2_t » Sat May 20, 2006 12:28 pm
yeah its the cold weather
I have actually adjusted my MBC a bit - it was hitting 15 psi the other day - really dont want more than 13 from a CT26
The problem with socialism is that eventually you run out of other people's money. -Margaret Thatcher
mr2_t
Postby Santa'sBoostinSleigh » Mon May 22, 2006 11:13 pm
mr2_t wrote:yeah its the cold weather
no not the cold weather, more like a function of the boost solenoid or something similar
Santa's Mega Sale
Postby Jazza » Mon May 22, 2006 11:34 pm
May pay to ask some of the turbo owners here. Depending on your engine, theres ALOT of things different (From what i understand) about maintaining your engine with a turbo compared to an N/A car.
Thats if you are completely unsure (I really dont have a clue how much you know :wink: )
1996 Curren - On Tardme
1992.5 EG Civic - 101kw@wheels. WTB 4x100 6.5in wide rims.
Jazza
Postby Inane » Wed May 24, 2006 11:49 pm
check your waste gate for gunk.
also check your turbo for shaft play.
get an electronic boost controller to keep that sucker in line.
more than about 15-17(I dont recommend more than 15) will lose power.
Inane
Postby Dell'Orto » Wed May 24, 2006 11:53 pm
Nah 15 is fine, mine was rather happy on 15psi for ages
