blackie wrote:and his connection with the little boy next door is gold
Timmo wrote:Apparently the lemon tree sub story is a little misleading: Lemon trees cant grow down there as its too cold??
True-No-Turbo wrote:I liked the part when he was Die casting pistons, that was classic - apparently he made alot of other engine parts aswell.
Burt began modifying his bike in 1926. His methods, to say the least, were unorthodox. He used an old spoke for a micrometer and cast parts in old tins although one American report has him casting pistons in holes in the sand at the local beach! He built his own four-cam design to replace the standard two-cam system and converted to overhead valves.
He made his own barrels, flywheels, pistons, cams and followers and lubrication system. In their final form he in effect hand-carved his con-rods from a Caterpillar tractor axle, and hardened and tempered them to 143 tons tensile strength. He built a seventeen plate, thousand pound pressure clutch and used a triple chain drive. He experimented with streamlining and, in its final form, the bike was completely enclosed in a streamlined shell.The leaf-sprung fork was dispensed with and what appears to be a girder fork from a 1925 - 1928 Prince substituted.
Rumor has it that Burt made his barrels from pieces of cast iron gas pipe, which he scrounged from the gas company after they had been dug up for replacement.
He reasoned that, after some years in the ground, they were well seasoned. He then made aluminum slices which he shrunk over the pipe to make fins.
Users browsing this forum: Bing [Bot] and 48 guests
