removing superstrut control arm
Postby Dirtbag » Sun May 21, 2006 8:31 pm
How do you remove a lower arm from superstrut ae101? Its the front left one as seen on this thread:
http://forums.toyspeed.org.nz/viewtopic.php?t=46474
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby Ae92typeX » Sun May 21, 2006 10:18 pm
should make sense just looking with it jacked up and wheel off. undo the bolts, crack ball joint and whip on a new/rebuilt unit.
Ae92typeX
Postby Lloyd » Sun May 21, 2006 10:23 pm
Except thats not the joint that usually fails on them?
Postby Mr Revhead » Sun May 21, 2006 10:25 pm
yeah its not the "common" one, but it still fails often enough no to be rare
Postby Lloyd » Sun May 21, 2006 10:28 pm
Were you asking how to get the one out that is circled in that picture, or the one at the front? If its the one at the front it should just be the 3 nuts/bolts holding it, then the fun bit is trying to get that link arm out without going slightly nuts and beating the living crap out of it with a hammer
Postby Dirtbag » Mon May 22, 2006 1:01 am
Yea the circled one, if you scroll down in the other thread, theres an exploded view of it all, with the arm circled, found that the ball joint can prolly b repaired by hpi engineering here in chch so no need for new one, hoping that they dont charge me to much for the repair!
My profile!
Dirtbag
