speedo reader ae101 e58
Postby bluemaumau » Sat May 20, 2006 11:18 pm
is the e58 mechanical or electronic?
hey im after some info on speedo readers in the gearbox.
im running a e52 which is cable /gear driven
however my loom is set up to run electronic speedo as my dash dosent have a speedo cable input, i.e its electronic.
so what i want to know is what the approx i mate length of any 4a model electronic speedo reader.
can anyone confirm if the e58 ae101 or even facelift ae92 speedo reader is electronic?
any help is appreciated
p.s whats the term for a "speedo reader" :oops: :lol:
will
Postby no_8wire » Sat May 20, 2006 11:27 pm
speedometer? no thats in the dash..
Speed sensor? :lol:
no_8wire
Postby bluemaumau » Sat May 20, 2006 11:35 pm
speedo sensor..
anyway i found this after a few pages of search
viewtopic.php?t=34190&highlight=speedo
but can someone tell me the length of a ae101 digital/electronic sensor?
gt_apex or gtz
Postby bluemaumau » Sun May 21, 2006 10:38 am
has anyone here made a e52 into a digital/electronic speedo sensor?
which sensor did you use?
Postby bluemaumau » Sun May 21, 2006 8:59 pm
hello? someone must know
Postby bluemaumau » Sun May 21, 2006 10:52 pm
anybody. i can see this being the last thing on the conversion - $&#$% $&#$% $&#$%
Postby sergei » Mon May 22, 2006 12:31 am
All the E series I've encountered have interchangeble speed spensors, I have swapped ST165 mechanical (E50F) with ST205 electronic with no problem, for example AE92 GTZ (E5X) mechanical and AE101 GTZ electronic also can be interchanged
Postby bluemaumau » Mon May 22, 2006 8:04 am
cheers man
Postby bluemaumau » Mon May 22, 2006 4:41 pm
CAN SOMEONE WITH A AE101 GTZ PLEASE CONFIRM WETHER OR NOT SPEEDO SENSOR IS MECHANICAL OR ELECTRONIC!
PLEASE
Postby sergei » Mon May 22, 2006 5:11 pm
ok AE101 is electronic. AE92 is not. They are straight swaps.
Postby sergei » Mon May 22, 2006 5:13 pm
I have AE101 GTZ damaged sensor laying some where in my garage, not sure if it works (plastic casing is damaged, possible to glue/solder on)...
Postby aesc » Mon May 22, 2006 5:15 pm
From searching at www.twincam.org/forums it appears the ae101 gtz gearboxes use an electronic speed sensor. They know a bit more about shit like this over there, as they do a lot of 4agze conversions into their ae9* Corollas
EX AE101 owner
2013 Ford Focus ST
aesc
Postby bluemaumau » Mon May 22, 2006 5:47 pm
thank you both very much. sergei is it possible to come and try that out out?
aesc- might have to join up then.
thank you both
Postby sergei » Mon May 22, 2006 5:50 pm
yeah sure I'm free after 7pm most of the time, PM me if you keen to come, location: North Shore, Glenfield.
