4AFE PERFORMANCE MODIFICATIONS
Postby Hybridd » Tue May 23, 2006 11:49 am
Hi Everyone
I know this may sound strange to the 4AGE fans , but is there any cars in New Zealand with the 4AFE (1600cc) engine in it... :?: And if so , what performance modifications can be done to this motor... :?:
Thanks.. 8)
AE92 South African Spec Hatchback
FXGT Wannabe
Hybridd
Postby Silent Knight » Tue May 23, 2006 11:50 am
CIA, Exhaust, Extractors would be the easiest first options.
After that I think it's probably easier just slapping in a 4AGE unless you want to spend money on maybe some cams and ECU...
Silent Knight
Postby sergei » Tue May 23, 2006 11:59 am
Force Induction.
Postby EssDub » Tue May 23, 2006 12:28 pm
4A-FTE time! :D
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby bluemaumau » Tue May 23, 2006 3:31 pm
yes we have 4afes and no dont modify them.
Postby 20v_rollaboy » Tue May 23, 2006 3:39 pm
Yep, slap a turbo on it and see what happens :lol: If I still had mine I would do that just to see what would happen.
20v_rollaboy
Postby sergei » Tue May 23, 2006 3:42 pm
I guess (4AFE are similar to 4EFTE in head design) they would go really well..
Postby 20v_rollaboy » Tue May 23, 2006 3:46 pm
Anyone know if a manifold from a 16v 4age would fit on a 4afe?
20v_rollaboy
Postby Hybridd » Tue May 23, 2006 3:52 pm
Hi guys...thanks to everyone for their replies....I just wanted to post this to see what you readers would say : There is a performance modification here in South Africa that allows the 4AFE to beat/run ahead of the Twincam 16 valve 4AGE and the 20 valve silvertop and some blacktops : It has the following mods :
Gasflowed and ported head
Bigger intake and exhaust valves
280 degree intake cam
276 exhaust cam
High rev spring kit
Head skimmed
38mm exhaust branch (extractor... :roll: )
50mm exhaust system
Dastek unichip
Adjustable Fuel Pressure Regulator
Stock Bottom End
P.S : this is a friends car and he revs to 8000rpm and there's no problem : He races often and wins quite well against most 20 valves... 8)
What yall New Zealanders think of this.... :?:
Just wanted to let yall know...Cheers.. :wink:
FXGT Wannabe
Hybridd
Postby HELBND » Tue May 23, 2006 3:55 pm
Hybrid-SA wrote:Hi guys...thanks to everyone for their replies....I just wanted to post this to see what you readers would say : There is a performance modification here in South Africa that allows the 4AFE to beat/run ahead of the Twincam 16 valve 4AGE and the 20 valve silvertop and some blacktops : It has the following mods :
276 exhaust cam
High rev spring kit
Head skimmed
50mm exhaust system
Dastek unichip
Stock Bottom End
its interesting, but the fact remains, that for the same money, you could get a 20v to run faster :)
HELBND
Postby Silent Knight » Tue May 23, 2006 3:55 pm
Sounds interesting but to be honest I prefer twin snails above all else... :wink:
Silent Knight
Postby no_8wire » Tue May 23, 2006 3:56 pm
well if you spent all the money that would have been poured it to that 4afe into a 4age...well that would be a different story...
no_8wire
Postby 20v_rollaboy » Tue May 23, 2006 3:59 pm
What car is this in?
(and where bouts in Durban you from?)
20v_rollaboy
Postby Hybridd » Tue May 23, 2006 4:03 pm
Guys...You all right...If the money was spent on a performance derivative Toyota motor (4AGE) then most definately he would have more bang for buck...but here in South Africa there was many heated debate that the 4AFE is only a "economy engine" etc...So in order to prove a point to many a sceptic out there...my friend went out and done this mod to his 4AFE and he started busting left right and centre...I am sure modded 4AGE'S would give him though....This performance mod is offered by a specilist Toyota Tuner in Johannesburg (S.A) for the equivalent of 1500 NZ Dollars...I think...if my currency converter is right... :roll: Well all i'm saying is that its nice to know for us 4AFE owners that there's actually a little untapped power in that motor.... 8)
FXGT Wannabe
Hybridd
Postby Hybridd » Tue May 23, 2006 4:06 pm
20v_rollaboy wrote:What car is this in?
Its in exactly the same type of car as in my sig. below...Me and my friend have the same colour as well...I am from Reservoir Hills...Next to Westville in Durban...very close to the city centre... :wink:
FXGT Wannabe
Hybridd
Postby no_8wire » Tue May 23, 2006 4:07 pm
only 1.5k? 8O
In nz that would cost at least 3...
no_8wire
Postby sergei » Tue May 23, 2006 4:07 pm
well comparing this list, and price of 2ZZGE or even half of the mods of 20V, I would be more inclined towards Yamaha design (GE).
Especially that 4AFE need that list just to beat stock 4AGE... I think to modify 4AFE second most cost effective way is to slap on the turbo and run say 7psi of boost on stock internals. The first most cost effective way would be to sell the car and buy a 4AG(Z)E or even 3SG(T)E powered vehicle, also it would have an advantage of having bigger brakes, and better every thing overall.
Of course you being located where you don't have access to these sort of vehicles (I thought they had 20v in SA)....
Postby Hybridd » Tue May 23, 2006 4:12 pm
sergei wrote:well comparing this list, and price of 2ZZGE or even half of the mods of 20V, I would be more inclined towards Yamaha design (GE).
Hi Sergei...I understand what you are saying and I agree.... 8) ...We do have the 20 valve (Blacktop only) Silvertop available as an import...Many of my other Club Member friends have 20 valves and they are struggling to mod this motor (Apparently it comes near perfect from the factory [head] and other stuff)...Well they can't get camshafts etc...All they can do is maybe add ram tubes...with bonnet scoop etc...What mods do yall do with the 20 valve engine....Yes a 4AFE with bolt on Turbo sounds nice...Will the internals (stock) handle it... :?:
FXGT Wannabe
Hybridd
Postby Hybridd » Tue May 23, 2006 4:17 pm
no_8wire wrote:only 1.5k? 8O
I guess because its a 4AFE and not 4AGE so parts are cheaper...maybe... :roll: :
FXGT Wannabe
Hybridd
Postby 20v_rollaboy » Tue May 23, 2006 4:59 pm
Hybrid-SA wrote:I am from Reservoir Hills...Next to Westville in Durban...very close to the city centre... :wink: [/b]
Im originally from the Bluff :D . But that was 7 years ago
20v_rollaboy
Users browsing this forum: Bing [Bot] and 16 guests
