All help appreciated
sergei wrote:I will loose power going bigger throttle body on stock engine/ecu.
crispy'86 wrote: also possibility of removing T-vis butterflies as increased air flow into the engine helps every little bit you can get.
Jebus wrote:crispy'86 wrote: also possibility of removing T-vis butterflies as increased air flow into the engine helps every little bit you can get.
Have ya driven with TVIS disconnected so theyre always open? Give it a go, $5 says youll hate it.
Ebola_One wrote:Have you considered a Honda B-series throttle body? smallest is 58mm (B16A1) and go up to 62mm (ITR, Accord Euro's).
I think there also might be a 64mm TB, but I'm not 100% sure.
